How much does the driveshaft weigh?
Old Feb 13, 2002 | 07:45 AM
Sideways's Avatar
Default How much does the driveshaft weigh?
I am curious as to the weight of the S2000 driveshaft. Not wanting to remove mine, I am looking for someone that has removed theirs in the past and possibly weighed it. Thanks
Old Feb 13, 2002 | 12:22 PM
The Reverend's Avatar
Haven't weighed it, but I have had it out. It's light. Not worth trying to make a cf one, if that's what you're thinking - you wont save any real weight.
Old Feb 13, 2002 | 01:01 PM
RT's Avatar
RT
Same here, had it out more times than I'd care to admit to, but haven't ever weighed it. Not only is it light, but both ends have some seriously funky sh!t going on. If you were to do an after market shaft, you'd probably get stuck using the stock ends which account for most of the weight to begin with (~80%?).
Why? What's cook'n?
Old Feb 13, 2002 | 02:15 PM
Sideways's Avatar
I was crusing www.iedls.com/ and wondering.
Old Feb 13, 2002 | 03:16 PM
Schatten's Avatar
the driveshaft uses cv joints, not U-joints - that's where a lot of the weight comes from.
rough guesstimate, the stock driveshaft with cv joints weighs just over 30lbs. that's quite a bit actually, not exactly light.
I remember replacing my driveshaft in the Mustang years ago with a FMS one - all aluminum with slip yoke and U-joints - all for $139. Pretty cheap, and the stock unit weighed just over 30lbs. The replacement weighed only 7.5lbs with joints.
If you want a CF unit built, it will run you approximately 800 bucks and you'll need to give up your stock unit while they rework it. A lightweight aluminum version wouldn't be a bad idea, and would need to be balanced. But most of the weight might be in the cv joints.
Old Feb 13, 2002 | 04:12 PM
S2Krazy's Avatar
I looked at mine when the car was on the lift for an oil change. I can't believe how damn small it is!
Old Feb 13, 2002 | 04:18 PM
cmnsnse's Avatar
Ill bet that you could replace those CV joints with quality U-joints and not know the difference, seeing as the angles dont get very extreme between the tranny and diff. Maybe you'd need to compensate for extention, but there's a way.
I would have figured more than 30lbs though.
Old Feb 14, 2002 | 07:28 AM
I've had mine out a few times, and it didn't weigh 30 lbs. I'd hesitate to say it was much more than 15 lbs.
Old Feb 14, 2002 | 11:58 AM
cmnsnse's Avatar
OK memory fart - seems heavier when its on your chest, Id guess between 15-18 - its just heavier than it needs to be. Its gotta be the joints. Ill weigh the damn thing next week when I get my friggn car back!! If theyre not done with it, Im just taking it damn it!
Old Feb 27, 2002 | 01:13 PM
cmnsnse's Avatar
Ok sorry Rev, it is 15.5 lbs
but thats not with a scientific scale, just a bathroom scale
But then I think alot of engineers have used a bathroom scale in the past
SC_Highlander
Oct 13, 2012 08:12 PM
gforcebean
Jul 16, 2010 11:41 PM
OldDogmeat
Sep 24, 2009 05:12 AM
Sub-Zero
May 2, 2005 05:05 PM
Rick
Jul 9, 2002 01:38 PM
