How much oil to add?
Old Jan 11, 2004 | 06:03 AM
skyyonrox's Avatar
Default How much oil to add?
Do the x's on the dipstick equate to some unit of measurement? My oil level is near the lowest x and I would like to add the correct amount of oil without any trial and error. Any advice is appreciated.
Old Jan 11, 2004 | 06:44 AM
ninegrand's Avatar
I belive someone had posted a general formula but I can't remember what it was (sorrry).
From my oil change experience with this car if you are at the bottom of the dipstick, you should need about two quarts.
That being said I ALWAYS add a little and check. Only way to be sure IMO.
Old Jan 11, 2004 | 07:39 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
From the bottom of the bottom X to the top of the top X should = 1 qt.
Old Jan 11, 2004 | 07:37 PM
RazorV3's Avatar
each X represents 200 mL, as billman said, from bottom x to top x, its exactly1 quart.
Old Jan 11, 2004 | 07:59 PM
skyyonrox's Avatar
Thank you. Excellent response.
-Andrew
S_KAR_G0666
Sep 14, 2011 02:17 PM
okcbrad
Apr 3, 2008 07:00 PM
S2KnLA
Feb 7, 2007 02:54 PM
GotRPMs
Oct 31, 2003 08:18 AM
Woodwork
Feb 22, 2001 09:42 AM
