How often should throttle cables be replaced?
I noticed mine is kinda gettin loose, but should I replace it or just adjust it to make it tighter? Or should they never have to be replaced unless broken somehow?
Some slack is required for the proper operation of the throttle body. If the cable is too tight you increase the risk of throttle cable breakage and damage to the butterfly in the throttle body.
