How to Properly Lift a Honda S2000 with a FloorJack
Old 07-14-2015, 07:05 AM
  #31
Themikewoo's Avatar
Originally Posted by cleenyc99
y wouldn't you just put the jack stands on the sub frame front and rear? I find this to be the most stable and not damage anything. also lift the back from the sub frame and not crush the diff bushings. also a good Idea to always double check the jack stands to insure that all four corners are making full contact with the floor after its up on all four. when lifting any car jack it up and lower it down slow ensure the wheel don't get caught on crack or small rock and the jack slips. also I keep a fifth jack stand next to me when working and I prefer 6 ton stands due to the wider base. only a few bucks more when buying. just an idea use your head do what you feel is safe. lmk if there's something unsafe about this always good to hear suggestions
Thanks for the suggestion. I have never used the frame but next time I'm under the car I'll take a look.
just an fyi if using jack stands on black top be careful the stands don't sink into the hot asphalt
That is a good tip. Post that in the YouTube comments as well!
Old 07-14-2015, 07:06 PM
  #32
Yaupon's Avatar
In retrospect, Honda should not have had 2 tabs in the front that look so similar...when only one tab is the correct jacking point.
Themikewoo
07-03-2015 05:54 AM
papdoc
08-26-2014 07:53 AM
jimi
12-04-2013 12:56 PM
steguis
30
11-18-2013 04:56 AM
slash2fx
10-15-2011 08:23 AM
Quick Reply: How to Properly Lift a Honda S2000 with a FloorJack
