How to remove engine and trans as single assembly?
Old Aug 13, 2015 | 09:21 PM
mroverkill's Avatar
Default How to remove engine and trans as single assembly?
Hey guys,
I'm looking to strip the engine and trans out of my wrecked s2000 for an engine swap project. Is the easiest way to do that to just drop the entire front subframe?
Old Aug 13, 2015 | 10:31 PM
Manga_Spawn's Avatar
Site Moderator
Yeah I would think the easiest way is to drop it out of the bottom thus dropping the subframe.
Old Aug 14, 2015 | 03:51 AM
Slowcrash_101's Avatar
Yep, drain all fluids, unplug all harnesses from their control units, label all wires so you know where they go, then disco the steeing coupler, the drive shaft, remove the shifter, and the front upper control arms. Plus another step(s) my dyslexic ass missed. Then you can unbolt the subframe support the subframe and tranny with a shipping pallet, raise the car while fishing the harness through the firewall.
Old Aug 14, 2015 | 05:02 AM
rmerchant3's Avatar
I've seen it done from the done and personally dropped it from the bottom on the subframe. IMO, from the bottom was by far easier.
Old Aug 14, 2015 | 07:09 AM
Topplayer's Avatar
Without a lift, I find it easier to drop the trans and pull the motor out the top.
Old Aug 14, 2015 | 08:51 AM
I'm spoiled I guess. I work in an air conditioned shop and my lift lowers flush to the ground and can go up to 20' in the air.
Old Aug 14, 2015 | 10:33 AM
V6 Donut's Avatar
This is exactly what I've learned to do. Last motor pull with lots of distractions ended me up at 4 hrs.
Old Aug 15, 2015 | 10:55 PM
mroverkill's Avatar
Thanks for the information, guys. I'm lucky enough to have a lift (but not lucky enough for A/C) so I plan to drop the two as a pair.
Old Aug 17, 2015 | 12:02 AM
riceball777's Avatar
With a lift for you drooping it from the bottom with the engine and transmission as one piece is the way to go. But for us normally people with just jack stands you must drop the transmission and use a cherry picker to pull the longblock from the top.
vduber
Apr 2, 2012 03:07 AM
kial007
Dec 26, 2009 07:27 PM
reving9kallday
Aug 28, 2009 07:35 AM
AusS2000
Apr 6, 2007 10:21 PM
Riceball
Oct 22, 2004 01:44 AM
