How to remove stock airbox?
When removing the 2 rubber pipes or hoses, do you take the metal piece that seems to be stuck in the larger one for the new intake, or do you just want the hose only? I can't seem to get either off, but I need to know what should actually pull off. Any ways to get this off easyer? It seems solid on the pipe.
Originally Posted by kush only,May 14 2005, 12:32 PM
cheap? how am i cheap? because i needed a quick answer so i can remove it today? or because u got offended because you are the ceo of helms? yea, get a life
I have a great life thanks.
Sorry to the others for the digression.
Anyone that can answer my question? I am in the process of installing it right now and I am stuck here.
Also, why do you need to know where the vacuum lines route to? Don't you leave these in the same place just hooked up to a new intake? Do you have to do this for an AEM V2?
DO NOT disconnect the vacuum lines without immediately reconnecting that line. This way, you won't get mixed up as you would if you had them all disconnected at once. Then, you're sitting there wondering which end is which.
If you get mixed up, see here to get some clarity:
https://www.s2ki.com/forums/index.php?showtopic=105368
Originally Posted by Hamiy,May 14 2005, 01:47 PM
Ok, thanks xviper. Going to be trying that now.
I don't see why I would need to take off any vacumm lines anyways.
