how to replace the control unit
Old Jan 24, 2008 | 04:59 PM
jetboater's Avatar
here's the installation manual for the security system--you do have to take the driver's seat out but it's only 4 bolts--the entire alarm system install is definitely DYI--I did mine myself---took about 3 hours for everything--if you only need the control module (under the seat) it'll take about an hour to change
http://www.handaaccessories.com/S2000/s2ksecurity.pdf
The entire security system (including 2 new remotes) is $277 for 2001-2003 models from HandAaccessories.com----- that'd give you the new module and new remotes programmed to it (and a bunch of wiring you wouldn't need!
good luck with it!
Old Jan 24, 2008 | 05:55 PM
wanabe's Avatar
good luck with it!
thanks jetboater!!
Old Jan 26, 2008 | 02:27 PM
wanabe's Avatar
picked up the part to do it myself and found out that it is the keyless control unit.... so not the unit that i thought, and not the one above-
the part number is 38380-s2a-a01
so it must be the one under the dash- will dig out the helms manual and see if that helps. looked under the dash and didnt see the unit, but guess it must be there!
bigbaddog
Oct 4, 2011 12:49 PM
macr88
Electronics
Nov 30, 2010 04:42 PM
wanabe
Feb 11, 2008 01:37 PM
Trip
May 27, 2005 04:34 PM
ianl
Jan 12, 2002 12:53 AM
