How safe are axle stands?
Originally posted by Sev
I was wondering how safe are axle stands, also can you use the stands by themselves to raise the vehicle or do you have to raise it using a jack first and then put the stand under?
If a jack is needed, what are the odds of the car tipping over on the side that has the stands while I am jacking the other to place the stands?
I don't know the front and back jack points on the car, is side to side jacking and then putting the stand as good?
Also, should I put the stands at the jack points or somewhere else?
Thanks everyone.
Thanks everyone.
A Helm's manual will detail exactly where the front and rear jack points are. Its kinda hard to explain without pictures.
Serious question:
If I jack up the passenger side of the car, put in jackstands on that side, then jack up the driver's side and put jacks on that side, will I damage anything?
I did this twice for reasons that made sense at the time, and I am now having trouble with my suspension on the driver's side. I am wondering if this jacking procedure caused the problem.
Tanq
Tanq
[QUOTE]Originally posted by Tanqueray
[B]Serious question:
Jack the front of the car first, not one of the sides. It's much more stable this way. Also please use wheel chocks when jacking up the car.
A good axle stand is the best way to support a car with the wheels removed. I always shake the car sideways before I trust it when it is on the axle stands. I would rather have it fall on the floor than on me. I must admit that I also have the floor jack still under the car when I am testing the axle stand placement. I really don't want it to fall off the stands.
