How is this sensor supposed to be connected?
Old Mar 10, 2007 | 06:40 PM
SenderGreen's Avatar
Originally Posted by s2k rookie,Mar 10 2007, 06:13 PM
Can i buy that coolant at like autozone or something.
also, what type of oil should i use. Brand and type.
Get your Coolant from the dealer (Honda Type2 Coolant I gallon OL999-9011 x2). Techinically you are supposed to able to use any Ethylene Glycol based Coolant that is free of both Silicates and Borates. Never Dex-Cool (orange).
Long story short, just buy Genuine Honda Type2 from your dealer. I think I got 2 gallon jugs for $16.00 even. I wouldn't bother trying to find a substitute. I did some reading about Coolants (several years ago now) and basically they are formulated differently for different cooling systems. Some contain additives that are actually supposed to plug microscopic holes in the system over time. I'm not talking about the "fix-a-flat" stuff for radiator, just coolant. Other's are supposedly additive free. If the wrong coolant is put into the cooling system or mixed into a system it can cause serious damage.
Just use Honda Type2 coolant, it is the right stuff for the S2000's cooling system. Don't mix it with your Type1 coolant. Flush the system first.
I have no way of knowing if it is true, but I have been told that Honda's coolant is a high quality product regardless.
Old Mar 10, 2007 | 07:17 PM
s2k rookie's Avatar
hey thanx for all the info. Why switch to type 2 if my car already has the type 1. Wouldnt it make more sense to just keep using type 1.
Old Mar 10, 2007 | 07:56 PM
I think it is discontinued. That dosen't mean you won't be able to find some really old stock somewhere. One reason would be once it is Blue you will be to visually identify what type of coolant by color, as there is no Blue Type1.
I also just noticed that there is more detailed info on Coolant change in the Owners manual then in the Service manual. I actually just went out and filled my resivoir to MAX line with the system cold.
I also noticed this in the Owners Manual (MY03):
Always use Honda All Season Antifreeze/Coolant Type2. This coolant is pre-mixed with 50 percent water. It does not require any additional mixing.
If it is not available, you may use another major-brand non-silicate coolant as a TEMPORARY replacement. Make sure it is a high-quality coolant recommended for aluminum engines. However, continued use of any non-Honda coolant can result in corrosion, causing the cooling system to malfunction or fail. Have the cooling system flushed and refilled with Honda antifreeze/coolant as soon as possible.
It sounds a little more urgent then the normal "We recommend only Genuine Honda" marketing spiel.
Old Mar 11, 2007 | 08:53 AM
Slows2k's Avatar
Originally Posted by SenderGreen,Mar 10 2007, 08:36 PM
Hey Billman250 or Slows2k, When the engine is cold the cooling system sucks coolant from the resivoir into the system. When the cooling system is hot it spits coolant overflow into the resivoir. Is this right? With the engine ice cold (overnight) how much coolant should be in the resivoir? To the MIN line? To the MAX line? Or in between MIN and MAX? I have it just a hair (1/4" to 1/2") over MIN line with the engine ice cold right now. Also, I do believe I got most of if not all the air out of the system. I watched the temps and put about a 100 miles on it. Would that effectively purge any remaining air from the system? Thanks.
Yup, that's how it works. The coolant level needs to be at least between the Min/Max.
The cooling system will self bleed through the reservoir. Even though you bleed the air from the system when changing coolant, some air is still left behind.
Old Mar 11, 2007 | 05:31 PM
Thanks for the clarification Slows2k.
Old Mar 11, 2007 | 06:00 PM
Squeezer's Avatar
you can use any coolant in the S2000 as long as the label on it says silicate-free. if its a different color then what you have in there now, do a drain, flush, and fill.
E4RTH WORM JIM
Jul 1, 2016 11:03 AM
CrimsonCore
Feb 3, 2014 08:44 PM
NFRS2kSi
Mar 5, 2007 07:34 AM
Venomous S
Mar 24, 2006 05:55 PM
gpiazza
Sep 26, 2001 06:45 AM
