Hydrolock
Old Dec 18, 2010 | 03:52 PM
it'S2klean's Avatar
Angry Hydrolock
Call me dumb, but screw Florida rain and F^CK Cold Air Intakes, didnt know the puddle would be so deathly deep.
Waited a little while after the car died and i pushed it as far out as i could, tried to start it, made a little rumble than a nice POP and than the starter made no more crank. Any suggestions?
MERRY CHRISTMAS!!!
Old Dec 18, 2010 | 04:00 PM
zeroptzero's Avatar
pull the plugs and let it dry out , there might be a chance that it's not ruined. I think it was Billman250 that posted on how to revive a water locked engine.
Old Dec 18, 2010 | 04:02 PM
it'S2klean's Avatar
Even after i tried starting it and it clearly wont turn?
Old Dec 18, 2010 | 04:07 PM
zeroptzero's Avatar
water won't compress if the cylinders are filled, pulling the plugs might allow you to turn the engine and push out the water.
I would dump the oil, pull the plugs and coils and see if you can get it to turn over by hand with a wrench on the crank pulley. If it turns after that then let it dry out, run new oil and a filter in it, reinstall plugs and coils when dry and see if it starts. PM Billman250 for some advice as he has saved some hydrolocked engines.
Old Dec 18, 2010 | 10:17 PM
davidc1's Avatar
Wait!! Don't dump the oil and then try to turn it over! There's no oil in it.
Pull the plugs, crank the engine, and you'll get a geyser of water shooting out of the plugs. Let it dry. Do a search for hydrolocked engings.
Old Dec 19, 2010 | 05:22 AM
zeroptzero's Avatar
Yeah I meant changing the oil when I suggested dumping. Oil and water won't lubricate very well if you crank the engine with the old oil. I would change the oil and filter once before cranking, if the engine seems salvagable and can fire up then change the oil and filter again before putting it back on the road.
Old Dec 19, 2010 | 05:57 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
pull the spark plugs out, then crank it many times. this will shoot the water out of the cylinders.
If you would have done this first before trying to start it, you'd be driving it right now. sounds like you already broke the engine with the starter.
NEVER TRY TO START A HYDROLOCKED ENGINE. Pull the plugs first. This could have been a simple save.
PM me ur cell I'll walk u through. Maybe you'll get lucky.
Old Dec 19, 2010 | 08:24 AM
HondaRehab's Avatar
Banned
^^^ word
All that water the sucked in through your intake ended up in your cylinders. Your only chance of salvaging your motor is to pull the plugs and crank it over to shoot all that water out.
Good luck man.
Old Dec 19, 2010 | 08:42 AM
Shadow_S2K's Avatar
Former Sponsor
What CAI were you running?
Old Dec 19, 2010 | 10:14 AM
zeroptzero's Avatar
this should be stickied with so many people still running CAI's on their cars.
