Hydrolock
Originally Posted by 352s2000,Dec 21 2010, 12:40 PM
^dayum.
That sounds like karma!! Is the AEM designed in a way that allows water to pool like that easily? I have the fujita CAI and I seem to think the way the filter is attached would prevent water from gathering from dripping through the hood.
Remember, it takes really little water to "plug" a cylinder. Our engines are 2.0L +/- 0.2,
divide that into 4 cylinders and the air we move is 500cc per cylinder. there is an airgap at TDC or 500cc , multiply that with 0.117 (compression ratio) = ~ 60cc.
If we get even 60 cc of water into ANY of our cylinders kiss it goodbye.
I've been asked to share more information about plugging the hood drain hole which leads to the CAI air filter.
https://www.s2ki.com/forums/index.php?showt...0&#entry1909883
This issue is more prevelant on AEM V2 since the filter is tilted upwards which allows the water to accumulate in the elbow of the CAI, so when you turn on your car after leaving it outside in a rainstorm, it will injest the water in the elbow in one shot and hydrolock.
Also it's easy to create a shield out of a old plastic flowerpot or bucket.
^ ^ ^ ^ That wont help much with immersing the filter in the water, but it will help keep it dry in the rain. The Injen i was told has a bypass filter but obviously it either doesnt or is not reliable enough.
My little contribution, just starting the engine when it rained on the car. I was parked on the driveway. Result driveshaft broke in two pieces, thank you Mister AEM.
http://importzone.forumactif.com/t915p45-t...0-new-photos-p7
You just have to register on the forum to see the pics.
puffman20
May 23, 2004 09:14 AM
