I got a buzzzzzz! Need advice!
Old Mar 11, 2004 | 06:01 PM
Ballistic's Avatar
i go tthis too...hmm interesting. It only started after I got the tsb. FYI, my clutch feels like its sticking too.
Old Mar 11, 2004 | 07:10 PM
cdelena's Avatar
We have found that this sometimes happens if the center bolt is left out of the heat shield. You can't easily see it is missing but you can feel it.
Old Mar 12, 2004 | 01:01 PM
ItalianBucwheat's Avatar
Which heat shield? I presume you are talking about the exhaust heatshield above the cat and the resonater.
Thanks for the Input Cdelena
Old Mar 12, 2004 | 01:35 PM
cdelena's Avatar
[QUOTE]Originally posted by ItalianBucwheat
Old Mar 12, 2004 | 01:47 PM
thomas's Avatar
i had that once when i was when it would decel at low rpms. ended up being my oil was low. i would say to top it off just to make sure.
thomas
Old Mar 12, 2004 | 05:21 PM
03S2KAY's Avatar
i have the same problem....in between 2800 to 3200 rpm's. WOWW that is annoying.I had this buzz with the top up only. i thought it would go away when i put the hardtop on, but hell no it kept on buzzing so i took the spare tire of, got in the car drove it and ...BUZZZ. man i gave up on it, however it sounds as if its coming from the rear of the interior.It may be a heat sheild problem but i havent had the chance. And yes this i caused by heavy vibration, due to the fact that it started when i installed the hks exhuast.well at least i know its not just my car
Old Mar 12, 2004 | 05:48 PM
Thanks Cdelena! I'll Check for that bolt on the header shield.
Thomas oil is good to go ...thanks for the suggestion
03s2kay I feel your pain. It can be very frustrating. I will find this buzz. If I have to take one piece off at a time and test it until all I have left is the frame I will find it. I will fix it. Only a matter of time.
Old Mar 30, 2004 | 10:09 PM
topcat7111's Avatar
I also have this buzz... also i have this annoying buzzing sound from 3k to 3.5k coming from the bottom of dash area. It does this in all gear, either accelerating or decelerating. All this happen after i had my Invidia exhaust installed.
Old May 4, 2004 | 07:32 AM
p0pe's Avatar
(back from the dead)
Any update on this? I just picked up a 01 and I have a similar problem... a very light mettalic buzz/rattle sound.
Old May 4, 2004 | 03:00 PM
sebrings2k's Avatar
is it a buzz or a rattle?
The mid. hanger on the Invidia is known to hit the diff. mount in certain cases.
I would check the passenger side diff. mount for rub.wear marks.
