I need Tips on replacing airbag system
Old Jan 29, 2009 | 10:11 AM
Jettin169's Avatar
Default I need Tips on replacing airbag system
I'm currently replacing my complete airbag system to an 01' AP1 (both airbags, seatbelts, and SRS unit. I have replacements from a parted out 02' but wanted to know if there was any particular way these need to be installed. I don't want them deploying once I hook my battery back up after the install. Any advice would be greatly appreciated!
Old Jan 29, 2009 | 11:20 AM
Stratocaster's Avatar
Buy a service manual and follow it to the letter. www.helmsinc.com
Old Jan 30, 2009 | 12:38 PM
S2S's Avatar
S2S
all you have to do is take the battery off, change everything and you should be good to go. if the air bag light is on there is a proceedure to turn it off.
find the yellow 2 wire plug that plugs into the fuse box, jump it then turn the key on, when the light goes out, dissonnect jumper, when the light comes back on reconnect the jumper, then the light should flash twice. that means the system is set. dissconnect jumper and plug it back into the fuse box.
if you not confident get someone who is, but its pretty easy. good luck!
Old Jan 30, 2009 | 07:09 PM
Kirpich's Avatar
^Yep.
I did it, same replacement (make sure all componenets come from one car). Same procedure, works fine, about a year later, everything is still ok.
don't be afraid! Just do it, I did, the very first try, it worked!
S2005x
Oct 8, 2025 02:06 PM
mikefifth
Oct 21, 2014 02:55 PM
OVER 9000!
Nov 19, 2013 08:12 AM
redap186
Apr 18, 2011 04:50 PM
S2KVITO
Aug 9, 2010 08:03 AM
