Idle concern
Old Jan 5, 2016 | 10:46 PM
Honda2002's Avatar
Default Idle concern
My 2003 s2k usually idles around 900 rpm, after i go driving the idle drops down to roughly 400 rpm and sometimes stalls
Old Jan 5, 2016 | 11:38 PM
Hasan Shaikh's Avatar
I think you need to clean your idle control valve. There is a DIY on the forum.
Old Jan 6, 2016 | 04:21 AM
JuicedS2K's Avatar
Check voltage at TPS. Closed throttle should be .5v and WOT should be 4.5V input to the PCM. Possible it can be your issue along with IAC.
Old Jan 6, 2016 | 11:45 AM
Honda2002's Avatar
Thanks guys i will check the idle control valve tomorow
Old Jan 7, 2016 | 08:48 AM
vtec9's Avatar
Also check the map sensor. There's a little air channel that runs between the throttle body and intake manifold that get clogged and impinges flow to the map sensor, and can cause issues regulating idle after removing throttle. Just be careful when unbolting the TB that you don't harm the gasket.
Old Jan 23, 2016 | 10:31 AM
jean-roch's Avatar
All s2ki do the same, ap1 & ap2, new or older!
FIRSTCAR-S2K
Sep 30, 2015 03:06 PM
cbs_24
Jul 16, 2014 03:36 PM
OMCMT
Jul 1, 2014 06:26 AM
amkaluta
May 19, 2010 02:34 PM
alfman240z
Feb 22, 2009 07:41 AM
