Idle hiccups
Old Jun 21, 2014 | 08:06 PM
OMCMT's Avatar
Default Idle hiccups
Quite regularly the car seems to almost idle out and turn off. The car starts to shake too. Anybody have experience with this issue?
Old Jun 22, 2014 | 03:21 AM
clio's Avatar
Try cleaning the iac valve and/ or replace map sensor.
Old Jun 24, 2014 | 10:40 AM
Vtbbs2k's Avatar
Does the car stall?
Old Jun 30, 2014 | 04:49 PM
OMCMT's Avatar
Originally Posted by Vtbbs2k
Does the car stall?
not yet but it gives the feeling like it might..almost as if its bogging down prior to a stall.
Old Jul 1, 2014 | 06:26 AM
vtec9's Avatar
Million threads on this, all the info you need can be found by searching. Basically you should start by cleaning the map sensor air channel between throttle body and intake manifold, and map sensor which sits on top of the throttle body. If that doesn't fix, you should remove and clean the IAC valve which is bolted on to the side of the intake manifold and has coolant lines that connect to the throttle body. Both of these are uses to maintain idle, and one of both can cause the dip in idle.
blink962
Oct 2, 2016 12:30 PM
Honda2002
Jan 23, 2016 10:31 AM
alfman240z
Feb 22, 2009 07:41 AM
disboibcrazee
Oct 16, 2006 10:12 PM
bunjimobile
Jan 24, 2004 10:28 AM
