Idle Surge on AP2
Old Jun 22, 2012 | 08:19 AM
StevenS's Avatar
Finally had a chance to take a look at the IACV. Didn't look bad at all, but I cleaned it anyway using a toothbrush, generous amounts of brake cleaner and compressed air. Bolted everything up and the car has been running perfectly for a couple of days now. I'm not sure if this did anything to help because the idle surge "fixed itself" after the original incident...
Thanks again to everyone who replied with suggestions!
Steve
Old Mar 9, 2017 | 09:03 PM
JrS2Stacks's Avatar
Originally Posted by Billman250
Surging like that is a stuck rotary air vane inside the IAC valve, 100% guaranteed.
Hate to bring up a super old thread but was this ever fully resolved? I've been experiencing the same symptoms, however, when the idle begins to surge, I turned the a/c on and it stabilized almost immediately. Any info on what would cause that?
Old Feb 27, 2022 | 01:09 PM
superpho's Avatar
had surging RPMs last night, read this post and did other research, and took a shot at the iacv. I disassembled, cleaned internals with carb cleaner (the valve did not rotate whatsoever). re-installed and RPMs were not surging after actions were taken. Idle relearn completed.
listen to Billman
Old Sep 26, 2022 | 05:06 PM
Gatormd's Avatar
What are you supposed to do on a 2006 AP2 without an IACV?
Was able to clear some codes and keep having P0507 come up. The car will idle up/down for about 7-8 cycles and then stay around 1800rpm and normalize. After driving through gears and coming to a stop it will continue with the surging for 7-8 cycles and again normalize.
Thoughts?!
Old Sep 26, 2022 | 06:01 PM
Slowcrash_101's Avatar
Thoughts?!
Either the pedal sensor, or a vacuum leak.
Old Sep 26, 2022 | 08:06 PM
Gatormd's Avatar
gone through the visible testing of hoses and cannot find a vacuum leak.
Didn't think about pedal sensor, I have noticed that the throttle map is much narrower (ie. 20 % throttle seems to be more like 50%wot etc)
How would I check the pedal sensor?
Old Sep 27, 2022 | 03:02 AM
The same way you'd check a tps. Check the voltage output.
eromeroS2K
Jan 12, 2017 05:29 PM
jamesnffc
Jan 30, 2013 02:19 PM
shadeys2k
Jul 1, 2011 04:54 PM
tk416
Jan 30, 2010 02:34 PM
Shipley
Jun 29, 2007 03:03 AM
