Ignition question
Old Apr 11, 2009 | 06:19 PM
lotus7racer's Avatar
Default Ignition question
Normally ignition fires twice for each revolution of the engine (4cyl 4 stroke).
My S2000 engine ignition question:
What is the value of the ignition pulse per revolution in S2000
My guess is 4?
Thanks people
Old Apr 11, 2009 | 07:47 PM
Stratocaster's Avatar
The ECU controls the ignition. it fires only when it is needed. It is not a wasted spark system. So it would be 2 pules per revolution.
Old Apr 12, 2009 | 02:47 AM
Thank you Strato....
so, Two huh?
I will change the programming.
Old Apr 12, 2009 | 11:31 AM
The ECU only sends the signal to the coil that needs to be fired, when it needs to be fired.
So what are you programing? (Yes, I know what your car is)
Old Apr 12, 2009 | 12:14 PM
SgtB's Avatar
Out of curiosity, when does the second spark occur? The exhaust stroke for emissions?
Old Apr 12, 2009 | 12:34 PM
I have a Dash2 Race technology - almost like a small laptop but a dashboard.
http://www.race-technology.com/products_2_3.html High tech dash. Anything you want, its in the dash. There is a configuration that I need to know to control the ignition.
If you spend a little bit more in the sensor, you can even calculate your horsepower.
Old Apr 12, 2009 | 01:34 PM
Stealth_SUX_'s Avatar
edit... read it wrong
Old Apr 12, 2009 | 04:46 PM
I have one too. I have just not installed it yet. For my install, I will be using an ECU cable to collect the info. Less wiring for me, more data available.
Old Apr 12, 2009 | 08:59 PM
how much did all that cost u guys... and does it display actual fuel level and engine temp..
Old Apr 12, 2009 | 09:55 PM
It can, you just have to connect it to what you want it to display. For the Fuel level, you have to mod the circuit. Engine temp is easy. It is a free standing full dash replacement. It also can be linked to the DL1 data logger. In my case I have both the DL1 and Dash2 linked to my AEM EMS by way of a custom ECU cable. So I can see it all with fewer connections.
