Ignition Switch
Old Aug 22, 2001 | 12:11 PM
Spryguy's Avatar
Default Ignition Switch
There is a rubber/soft plastic O-ring (for lack of a better description) between the ignition switch (key) and the plastic housing behind the steering wheel that is becoming separated on my Stook. I have tried reinstalling it with little to no success so far and was wondering if anyone else has experienced this problem and if so, how they fixed it.
Old Aug 22, 2001 | 05:24 PM
Takashi KazuMori's Avatar
When I installed an auto timer in the car, I took off the steering column to access the ignition wiring and stuff. So now, here's the tricky part of putting it back correctly. Split both of them apart ... Meaning the top piece and the bottom piece.
Then you can place the rubber ring around the bottom fitting of the steering column piece, next you place the top piece over it and that should fix that part. The hard part is getting the complete steering column to be tight fixed again. You'll need a torch and quite a small hand to fit through the tight space inside.
Lie down with your head facing the pedals, face facing the inside of the steering column and all the wiring. You will see a small securing plastic pin on the side where the two joints meet, that you will need to get that in place for the complete steering column to come secure. I hope you understand what I'm trying to say, it took me quite awhile to get it all tight and secure again with alot of effort.
Old Aug 23, 2001 | 05:44 AM
Spryguy's Avatar
Thanks Takashi...........You are right, sounds like a big job.......I had a feeling it might come down to this but was hoping to the contrary.........I'll give your method a try!
Old Aug 23, 2001 | 05:10 PM
Not that big of a job but certainly patience is the key to getting it right. Let me know how you go with it, sorry I can't provide any graphical explanations ... That will aid getting it right easier. Even though so, the securing plastic pin with the top and bottom piece behind/inside the steering column is very visible since there is nothing else in the way if you have a complete visual view from down under.
Old Aug 24, 2001 | 07:26 AM
Spryguy's Avatar
Will do......Thanks.
Al_G
Dec 21, 2014 05:17 AM
etang789
Jul 13, 2011 10:38 AM
K7S2KGSXR750
Bay Area For Sale
Sep 18, 2010 03:33 PM
Kremlin
Nov 6, 2007 03:54 PM
9kI4
May 8, 2007 04:57 PM
