Im not going any farther without opinions!
So I did the whole clutch setup. New bearings, plate, clutch.. torqued and installed transmission. I also just threw the slave on and pushed the clutch, I did not like the sound I was getting. I greased the fork, ball point on the slave and fork. It got a little better, but still it sounds bad. What do you think? The ping is happens when the clutch is pressed.
[media]http://www.youtube.com/watch?v=jT5oKIP7XHw&feature=youtu.be[/media]
hey I have the same problem, but i have never messed with the transmission or clutch. I got the s2k used so I dont know when was the clutch changed. could please go into more detail on how did you fix it? thanks
Exact sound? I think its the throw out bearing that sticks to the pressure plate. Easy things to do is to disconnect the slave (2-bolts) and grease the ball of the slave also the fork itself where the ball connects and where the fork snaps in the mount. This helped the sound, idk what stopped it but when I pressed the clutch fast/hard the noise went away, although the clutch fell to the floor and stayed there. I pull it up and no more sound, smooth clutch... no problems. Drove it and its perfect. I'll try recording a video of what I think the sound is.
yea it makes that same "thump" sound when it goes to the floor. If press it slowly and push it all the way to the floor, it doesnt make the noise. It makes the noise when I push it a lil harder, sort of like when you are shifting quicker.
Like I said, give some grease a try. Take the two bolts out that hold the slave, grease the ball and fork. You can pull the fork and look in there to see you you can see anything.
