immobilizer
Old May 13, 2007 | 05:34 PM
freshs2k's Avatar
Default immobilizer
my immobilizer signal keeps flashing. i tried a new ecu and i had it flashed with my key and it works but the immobilizer signal still comes on randomly and somtimes stays on for a few seconds at a time. so its not my key and its not my ecu. how do i replace the black box in the steering column? can i just replace that one piece in the system?
Old May 13, 2007 | 06:18 PM
Stratocaster's Avatar
All three parts of the system, make the whole system. The Key, Reciver and ECU. I assume you are still under warranty? Make it the dealer's problem. But if you have to replace it, it sells for 60 (list price). There are two screws holding it in place. Remove them and swap it out. It is not really hard, just cramped.
39730-S84-A11 IMMOBILIZATION UNIT
Old May 13, 2007 | 06:29 PM
freshs2k's Avatar
Thanks appreciate it. Do I have to get anything reflashed? My key? Just for replacing the receiver?
Old May 13, 2007 | 06:35 PM
I think you need to get the ECU recoded for the keys.
I have swapped it before and I needed to use the old one until the dealer recoded my car.
Old May 13, 2007 | 06:37 PM
Jano's Avatar
Mine does the same thing. Every once in a while the light flashes under hard acceleration right @ VTEC. Goes out in a couple seconds and the car starts and runs fine.
Not sure if I want to go to the dealer with an ECU harness tapped with the Comptech ESM. I'm sure it will be nothing but questions and problems.....
Old May 14, 2007 | 04:16 AM
freshs2k's Avatar
do they have to look at the ecu? cause i have had vafc tapped before i don't think they need to see the ecu to reflash the reciever do they?
Old May 14, 2007 | 07:38 AM
See it no, they plug into the ODBII port and program it.
Old May 14, 2007 | 08:00 AM
freshs2k's Avatar
cool thanks for all the help appreciate it
chirayufun
May 3, 2018 02:37 PM
EK9MAX
Nov 5, 2009 09:56 AM
ans2k
Apr 20, 2009 06:27 AM
DRE.
Oct 23, 2007 06:35 PM
