inlinepro head gasket
Old Jan 15, 2005 | 10:38 AM
20vmini's Avatar
Default inlinepro head gasket
hi i was wondering if the inlinepro 3mm stainless steel head gasket is reuseable thanks
Old Jan 15, 2005 | 01:18 PM
honda9krpm's Avatar
IMO, economically speaking, it's not worth it.
Old Jan 16, 2005 | 08:18 AM
20vmini's Avatar
could you please tell me more, are they no good to begin with? i need to lower my compression to run more boost
Old Jan 16, 2005 | 09:36 AM
alexf20c's Avatar
The lower compression ratio a thicker head gasket would give you is marginal, and wouldn't make any difference on your potential boost level. Not worth it.
Old Jan 16, 2005 | 10:57 AM
s2kboost's Avatar
do u knnow anything about cars lowering the compression if u want to run more boost is smart john lee from in line pro has a 3mm headgasket and he just put down 521 to the wheels and i am doing the gasket as we speek to my car.
Old Jan 16, 2005 | 11:41 AM
papa5murf's Avatar
you want to lower compression if you want to boost at a high psi..... the inline kit comes with a 3mm head gasket...
and getting a thicker head gasket will make a difference on your potential boost level....
Old Jan 16, 2005 | 11:54 AM
alexf20c's Avatar
Learn to speak English, and type it as well, before you try and talk down to me.
Yes, I know FI cars like lower boost (when you do it the half-ass'd way), but a head gasket ain't gonna make that much of a difference. And if you think you'll be at 521whp because you use the same head gasket, you'll be in for quite a surprise.
Oh, and just for the record, I'm at 548whp, 507wtq on 93 pump. No boost. No spray.
Old Jan 16, 2005 | 11:58 AM
papa5murf's Avatar
but that can't be numbers from your S...
Old Jan 16, 2005 | 12:22 PM
SpeedxRacer's Avatar
Is that from your LS1 motor you dropped in pacmans silver S2k where you chopped the sounds of a modded v8 in? LOL
http://www.srtforums.com/forums/showthread.php?t=100452
Old Jan 16, 2005 | 01:07 PM
9kFever's Avatar
Alex is such a tool show some pics or real videos and you might get respect. I also believe he claimed it was an ls6
