innovative mounts
Old Jan 31, 2010 | 12:09 PM
SpoolinU's Avatar
Default innovative mounts
i replaced my motor mounts with the aftermarket innovative mounts, is it necessary to replace the differential mounts?
Old Jan 31, 2010 | 03:40 PM
SpoolinU's Avatar
come on someone has 2 know
Old Jan 31, 2010 | 03:42 PM
goldenfri's Avatar
I didn't
Old Jan 31, 2010 | 03:54 PM
Neutered Sputniks's Avatar
I don't see why you wouldn't. It's the easiest mount to replace...
Old Jan 31, 2010 | 04:10 PM
SpoolinU's Avatar
it might be easy but i found them for like 450-750 bucks for mounts.. thats alittle crazyy
Old Jan 31, 2010 | 04:32 PM
Edited because I'm an idiot.
Thought you were talking about tranny mount, not diff mounts. NVM>
Old Jan 31, 2010 | 10:37 PM
21337R's Avatar
Are they broken? If not then I would say.... NO
BTW... how do u like the motor mounts? I'm about to buy some myself... which bushings did you go with?
Old Jan 31, 2010 | 11:04 PM
I went with the 75A (black).
Bit of a bitch to get on by yourself, but doable. I haven't had a chance to drive the car since installing them, so I can't give you a solid review however I can assure you the mounts are more solid than the stockers
BTW, I've seen that the 60A (red) bushings deform. There's a thread somewhere in these very forums that discuss it (apparently it's an issue Innovative knows about). I'd recommend going with the stiffer bushing (75A) to be on the safe side, YMMV.
Old Feb 1, 2010 | 06:59 AM
SpoolinU's Avatar
i went with the 75a(black) but haven't had the chance the drive the car yet either i just installed them, and want to make sure that i don't need to replace the differential mounts with stiffer ones.
Old Feb 1, 2010 | 12:55 PM
Stealth Operator's Avatar
Take a torch and get the car on the hoist, if 1 of the 4 or more of the differential mounts are broken, replace them. The differential mounts are quite soft and are easy to break.
bgoetz
Aug 23, 2014 03:21 PM
Ripcurl808
Sep 6, 2009 10:35 AM
news2kroller
Jun 22, 2008 05:37 PM
TexaS2OOO
Jan 4, 2008 05:49 AM
mikegarrison
Jul 26, 2004 11:41 AM
