Inspecting a differential
Old Jan 16, 2012 | 10:13 PM
Ippo Makunouchi's Avatar
Default Inspecting a differential
Hey guys my differential blew and im looking to buy a used one. Question is what are ways to inspect if a differential is in working condition that is off the car?
Old Jan 17, 2012 | 10:00 AM
longster's Avatar
At work we test it while its on the car. in your case. i would try spinning the center shaft by hand and make sure both output shaft are rotating smoothly with little resistance. and for the LSD check of the rear differential. (see below) since its not on the lift. do it by hand and see if the other wheel out put shaft on the wheel is rotating. Oh yeah ap1 rear diff and ap2 is compatible. only thing different is the drive shaft connection bolts of the center shaft of the diff.you can switch them out with ap1 to ap2 or ap2 to ap1 so it can directly bolt right on to one another diff. just unscrew and re screw tightly! look for ap2 rear diff definitely a lot stronger. good luck!
The Torsen type limited-slip differential (LSD) distributes optimum power between the two driving driveshafts according to the difference in torque demanded by the driving wheels. Under no circumstances should the engine be started with either wheel raised off the ground, such as using an on-car wheel balancer or when transporting the vehicle in the event of an accident.
Raise the vehicle on a lift.
Rotate either rear wheel by hand, and check that the other wheel rotates in the opposite direction. Check both wheels.
If the opposite rear wheel does not rotate, or if you can not spin the rear wheels at all, and the brakes are not binding, the limited-slip differential is faulty and should be replaced.
Old Jan 17, 2012 | 02:00 PM
zeroptzero's Avatar
Is it okay to run the engine with both wheels off the ground ?, I've done that a few times, with the engine in neutral of course.
Old Jan 17, 2012 | 09:25 PM
longster's Avatar
yeah its ok, but there no reason to for this procedure. check for the LSD just release the parking brake and rotate it by hand as stated on the Honda corp. service bulletin.
Old Jan 18, 2012 | 04:46 AM
zeroptzero's Avatar
thanks for the reply longster, I was just asking because I've run my car while it was on jackstands with both rear wheels off the ground after a part installation. Thanks for the reply to my question.
s2kq8
May 20, 2016 01:43 PM
RedSunS2K
Mar 20, 2014 06:54 PM
alricl
Nov 27, 2011 11:15 PM
mrscbw
Jan 15, 2009 11:02 AM
kfdon
Jun 28, 2008 04:33 PM
