Inspection Failed --> Catalyst not ready
Old Sep 30, 2004 | 02:01 PM
andys2k02's Avatar
Default Inspection Failed --> Catalyst not ready
Brought my 02 to Honda dealer for inspection couple days ago. Failed the inspection due catalyst converter is not ready. The tech told me to take the car out for a good drive over the weekend and bring it back on Monday. Catalyst converter fail could be due to not enough driven . How could this be when I putted 18K miles in the pass 11 months. I am really puzzled. Anyone has advise on this??
Old Sep 30, 2004 | 02:16 PM
xviper's Avatar
You haven't put in any "suspicious" fuel have you? I can't see a 2 year old cat failing. Even it just sat there, it still should be OK. I can't see how driving it for the weekend will change anything. Maybe they want to sell you a new cat for how many hundreds of dollars? I'd try another dealer.
Old Sep 30, 2004 | 05:10 PM
jwkim's Avatar
Former Sponsor
I thought emmssions parts warrented for 70k mile(or looong time). no?
Old Sep 30, 2004 | 06:01 PM
Slows2k's Avatar
The Convertor is covered for 8yrs/80K.
It sounds like the Tech just looked at the monitor list, and the covertor monitor was not completed. It does take specific driving conditions for the computer to run a system monitor.
I'd bet the convertor is fine, The Tech could have driven the car under the monitor enable conditions to get a "passed" result.
Every state has different emmisions testing laws, I'm not familiar with Texas law. It sounds like just a visual check, and a OBDII monitor check to verify all emmisons monitors passed and no DTC's stored.
Old Sep 30, 2004 | 08:44 PM
alexf20c's Avatar
All states have 8yr/80kmi warranty on emissions control devices. I believe California has 10yr/100kmi.
What kind of mods do you have on the car? Past repairs?
Old Sep 30, 2004 | 10:22 PM
Siepel's Avatar
Hi Andy,
Did you reset the ECU (or take off the battery cable) just before you took your car in?
In case of the above, the OBD system will not give the "readyness code" for catalyst monitoring and you will indeed have to drive the car for a while to set it.
This does not necessarily mean the cat is failing btw. and does not throw the MIL (Check Engine Lamp).
Regards,
Siepel
Old Oct 1, 2004 | 08:22 AM
andys2k02's Avatar
Guys, thanks for the responses
My car is a bone stock. I am paying mortgage and 2 car payments so no mod to it yet.
Siepel, someone from the dealer did take off the battery cable. I have to reenter my radio code after I got it back from the dealer. So this could be the case. Thanks
Old Oct 3, 2004 | 08:44 PM
s2000guy's Avatar
Seems to me that the vehicle failed the smog inspection because not all of your monitors have run. When the battery cable is disconnected the ECU will loose its memory and the car must be driven in order for the ECU to run the monitors( self check of emmission components such as 02 sensor, map sensor, CAT and so on).
ca86108
Aug 29, 2012 01:58 PM
Kingers
Jul 8, 2009 11:37 AM
(S2K4ME)
Apr 14, 2008 07:45 AM
RUSS H
Jun 5, 2006 12:31 PM
Ozy
Aug 18, 2004 03:25 PM
