Installing After Market Clutch and Flywheel.
Im almost ready to install my CC Stage 4 Clutch Kit along with my ACT pro-lite flywheel. I have almost everything done and now I pretty much just need to unbolt the trans bolts and it should come out. Is there any advice you guys can give from experience? I just picked up high temp grease from Honda for the throw-out bearing and clutch spline. Is there anything else I really need to know? And my friend swears that the pressure plate and fly wheel need to be torque, I feel that is unnecessary but what do you guys think.
I do validation for tissue digesters that they use in bio-medical testing. One time we had a tech close this 800lb door with these 55mm bolts, just went around in a circle and torqued all 20 bolts down to the specified 50ft lbs. After he finished, he just assumed they were all torqued properly and nearly 3 tons of a lye solution at 330 degrees Fahrenheit, and dissolved dead animals sprayed everywhere that the bolts where not properly secured. Had to use a Hazmat suit to clean up afterwards.
Point is there's a reason you tighten these bolts in steps and in a criss cross pattern. So that a all bolts are torqued evenly, and b so that the part is drawn to it's mating surface evenly as well. If you tighten a piece all the way carelessly you can warp the part and if it's not level the lever action you created against the threads will give you a false torque reading.
/pointless nerdism
/pointless nerdism
I just Installed my clutch today and I can say 100% that you should definitely torque your flywheel!! Pressure plate not as important but you might as well. Good luck for anyone trying this!
And I did reuse the flywheel and pressure plate bolts because they looked like they were in good condition. I also put some red lock-tight to be safe haha
