Installing K&N Air Intake
Old Aug 13, 2012 | 06:43 AM
Jazzman's Avatar
Default Installing K&N Air Intake
I am about to try to install the K&N air intake on my baby. I have almost no auto mechanic experience other than an oil change.
Is this well within amateur limitations or should I seek help?
Or is it a good intro for a bum like me?
-m
Old Aug 13, 2012 | 06:52 AM
S2KIrishman's Avatar
if you know how to use a basic set of tools, you'll be fine...its not difficult at all
edit: and thats how you learn how to start doing things, just take your time and follow the directions...working on cars is pretty simple once you learn the basics of how things work...dont let it intimidate you...working on your own car can be one of the most satisfying things you can do
Old Aug 13, 2012 | 06:58 AM
thebiz's Avatar
I found the hardest part was disconnecting the hoses. Other than that, it's not too bad. This was one of the first things I did as well.
Old Aug 13, 2012 | 07:03 AM
Jazzman's Avatar
Thanks,
I am having trouble detaching crank case vent hardline from the stock intake tube.
Any tools/tricks?
-m
Old Aug 13, 2012 | 07:25 AM
jh4db536's Avatar
Use some pliars with inner jaws (have a step, teeth to grip hose but won't crush or cut hose). Grab it and twist the hose on the fitting to break it loose. You should be able to pull it off easily after that.
Sent from my T-Mobile G2 using Tapatalk 2
Old Aug 13, 2012 | 07:38 AM
Jazzman's Avatar
tried, can't do it.
The hard hose is attached to another, making it immoveable.
I am also putting "teeth marks" on the hard pipe and I don't like that.
-m
Old Aug 13, 2012 | 08:31 AM
s2000maniac's Avatar
The hardest is installing that bolt that's close to the radiator fan....
Old Aug 13, 2012 | 10:40 AM
TougeS2k's Avatar
^ yes...
and ill tell you, ive installed 15 different intakes in my life and this one was the biggest bitch. so many little stuck hoses cuz my car is old. just ram a flat head screw driver between the rubber and the nub and yank. dont be gentle! lots of little nuts and bolts to assemble too. just make sure u have the time and be patient.
Old Aug 13, 2012 | 11:06 AM
ConanO'Brien's Avatar
i have done intakes on other cars (not on the s2000) and i can say if you change your own oil, you can put on a new intake.
Old Aug 14, 2012 | 12:36 PM
Saki GT's Avatar
Fwiw, I've used a pick to pull the hoses apart from the hard points on the engine - stick it between the hose and the hard point and work around to break the seal on them, then use some pliers to gently tug the hoses off. They get sticky after they've been on for a while.
Getting hoses off is hard, getting the mounting bracket on is hard too, the rest is easy.
xasrielx
Jan 15, 2010 08:59 AM
ar311unity
Apr 18, 2009 09:33 AM
MuttGrunt
Apr 9, 2008 08:50 AM
rkhondas2000
Jan 2, 2004 01:22 PM
