Installing a size 56 battery
Old May 23, 2005 | 03:47 PM
SoCalIsMyLife's Avatar
Default Installing a size 56 battery
How do I tie down the bigger size 56 battery? It is the same height as the stock one, just around an inch wider and longer. I just need a way to tie it down. Do i need a bigger holder? How will I hold it down?
Old May 23, 2005 | 03:49 PM
BTW: Here's the reason why I bought the Kirkland Size 56. It cost me exactly $1 more and has 125 more Amps than their size 51R. This one has 590CCA and 750CA. Pretty impressive for around $36!!!
Old May 23, 2005 | 05:06 PM
xviper's Avatar
When the base dimension is bigger like this, does it still sit inside the battery tray or does it sit on top of the tray? You may be able to get different, longer hold down rods and modify (bend) the bottom bit so it can run up the side of the battery and use a slightly longer bar across the top.
If it sits up higher, you'll need to make sure the terminals don't touch the hood when it's closed. That would not be fun.
I suppose you could also get one of those heavy duty black rubber bungie cords.
Old May 23, 2005 | 06:22 PM
it's the same height so I don't need longer rods. What I do need is a longer bar on the top that's narrower in the middle due to the vent holes. Where do I find one? hmmm... i wonder which car uses the size 56 batteries... And, I need to stretch the base quite a bit... how do i do that?
thetz99's Avatar
I got a Nascar brand type 34 made by Exide over at Sam's club for about $60ish that puts out CCA of 770 and CA of 950. It's only an inch wider and has the same length as stock so I extended the holddown, added a L-bracket, and isolated the battery from the bar with weatherstripping. It fits the space perfectly.
You never have to worry about running the battery down with this puppy.
Old May 23, 2005 | 06:25 PM
How did u extend the base?
Old May 23, 2005 | 06:29 PM
thetz99's Avatar
I sat it on the existing base, I might have extended the base with another flat bar that I could hook the threaded bolt to.
Old May 23, 2005 | 06:32 PM
hmmm... if I could find a car that uses size 56 then I could just snatch the bar n possibly a base from a junk yard and not have to make it.
I don't have many metal working tools so I'm trying to find as many pre-made parts as possible.
Old May 24, 2005 | 02:46 AM
fperra's Avatar
Just get an aluminum bar from Home Depot, cut it to size, drill two holes in it and you are all set.
Old May 24, 2005 | 04:16 AM
hboy7777's Avatar
a honda accord one will work... 94-97 i believe. look up some under hood picsof one im sure its what your looking for. also napa or autozone sells universal ones
geesquared
Nov 11, 2015 02:22 AM
FTW.inc
Nov 4, 2009 07:14 AM
jbotstein1
Jun 25, 2006 04:35 AM
jelliotlevy
Apr 26, 2002 09:26 AM
S2K4ever
May 11, 2001 09:20 PM
