Installing a STB
Old Aug 5, 2005 | 07:48 AM
jurn's Avatar
Default Installing a STB
I have a friend who`s a mechanic. He once told me that when installing a strut
tower brace, you should jack up the car so that the wheels are of the ground. This
would give the STB an improved effect.
Can anyone confirm this, or is it just a myth?
Old Aug 5, 2005 | 08:13 AM
SIIK2NR's Avatar
I would recommend it... but not everyone does it..
Same as with an X brace.. It's recommended but not everyone does it..
If you have the time to install it......then jack it up...
The consencus on the STB is that it has minimal if any effect anyways so going the extra step to jack it off the ground might just be a placebo effect....
Old Aug 5, 2005 | 08:24 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Makes no difference. A car this stiff is not going flex inwards or outwards at the shock towers simply by lifting it off the ground.
You will have to raise at least one wheel to lower the shock, if it's a Ti Comptech STB.
Old Aug 5, 2005 | 08:50 AM
jurn's Avatar
Ok
Thanks guys. I'll just jack it up then. Just to be sure
david woodham
Apr 4, 2011 12:23 PM
tagon42
Aug 16, 2008 03:24 PM
vifferman
Jul 30, 2003 12:56 PM
spessx
Jun 25, 2003 12:27 PM
Ajjra
Apr 17, 2003 08:20 PM
