Instructions for adjusting headlights?
Old Mar 8, 2002 | 07:02 AM
Squeezer's Avatar
Default Instructions for adjusting headlights?
Hi,
My driver side headlight on my S2k is pointing a little lower then it used to. The notch in the pattern is off a few degrees on the driver side. Does anyone have the instructions or can tell me what I need to do to adjust the aim of the headlight up a few degrees? I think there is a screw I turn clockwise to adjust it? Where is it located?
Thanks in advance!
Old Mar 8, 2002 | 12:40 PM
bbsilver's Avatar
This is from memory, so someone else needs to fill in the blanks.
There is a gray gear in the back of the light housing. It is between the HID bulb and the H1 high beam bulb. Use a philips (star) driver. CW = up; CCW=down. There is a small circular hole in the frame that the driver slips through. You have to temporarily remove the windshield fluid reseviour, for the driver's side.
Park the car on a flat surface. 25 feet from a wall. Measure the height to the ground from the little circle on the front of the light housing. Mark a temporary line on the wall that is 2 inches lower than height of the light. The upper line of the white part of both HIDs should be at the line.
------------- upper line
lower line---------
Old Mar 8, 2002 | 02:29 PM
bloomac's Avatar
Hey dude,
They offset headlights on all the S2000's so you don't blind oncoming traffic. It was manufactured that way. However, I leveled mine. Let everyone else be blinded by my Xenon's!!!
Old Mar 8, 2002 | 02:34 PM
bbsilver's Avatar
[QUOTE]Originally posted by bloomac
[B]Hey dude,
Old Mar 8, 2002 | 05:29 PM
Squeezer's Avatar
[B]Hey dude,
shkani04
Dec 5, 2011 04:49 AM
s2kdriver80
Mar 5, 2010 09:45 PM
J_STATUS
Apr 14, 2008 07:21 AM
SwansS2K
Nov 7, 2006 02:53 PM
infinity_racer
Jan 20, 2005 07:12 PM
