intake problem or something else
Old Aug 12, 2007 | 01:48 AM
dnewkid_24's Avatar
Default intake problem or something else
i got a problem with my s.
i went to a chevron gas station down at hesperian boulevard to stop and get some gas... everythingwas fine at that time but when i started to go down the road, i felt something wrong with my throttle response...
as i was steppping on the gas, i felt a different response from my car... instead of speeding up, the engine sounded like it is going to die... i tried downshifting, still the same response...
so i stop to check on it... i turned the engine off and started the car again... it sounded like it was "drowning"... i tried stepping on the gas, then the engine just died...
i called a friend of mine to come over and just try to check on what happend... he drives a Z and he said the same thing happened to him, only his still revs up to 40 mph... so he was still able to drive to a shop... then the shop found out that there was a small piece of something found in cat converter...
going back to my s, we tried to open the intake and there was smoke coming out... we checked if we could find anything in there that mightve clugged up my intake, but failed to find any...
i need help on this one... it really bothers me...
thanks for any response...
Old Aug 12, 2007 | 04:14 AM
terahertz's Avatar
did your friend with the Z go to that same gas station? maybe it was shitty gas.
Old Aug 12, 2007 | 06:59 AM
Z_refugee's Avatar
Hmmm. I had a Z and a similar thing happened to me. Turned out it was the mass air flow sensor. I'm still an ultra n00b when it comes to the honda but you might just check that.
Nic
Old Aug 12, 2007 | 01:50 PM
ssj_jared's Avatar
Spammer
check and make sure your map sensor is hooked up. I was playing around with my car one day and unplugged it and it did the same thing.. good luck
ALBERTS2K
Dec 22, 2019 11:05 PM
tcjensen
Aug 1, 2008 02:42 PM
dnewkid_24
Aug 14, 2007 09:00 AM
dnewkid_24
Aug 13, 2007 11:55 AM
djbert
Jul 28, 2007 06:34 AM
