Intercooler or aftercooler for SC?
This is some questions that I haven't seen answered. At least I couldn't find any. With pressure drop being equal at 1.2psi what would cool the air into the system better? If there is a link to another post that I couldn't find in the search let me know but I think this one is important. Thanks in advance.
At first I am looking to only run 7-8 pounds boost. Later I will up the boost with a build to about 10-12. I can do an intercooler for less than the aftercooler. That is why I am curious if one really tests out better than the other or if people just think the water cools better overall. I went through about four pages of search and came close.
http://forums.s2ki.com/forums/showthread.p...ght=aftercooler
I would say that at 7-8lbs the AW would be better because it has enough cooling capacity and a shorter path. At 10-12 you might be reaching the point where the extra cooling capacity is required and the extra pressure makes up for the longer path.
So I would say that if you are definitely commited to 10-12lbs go with the air-air but don't expect your set up to be optimal until you get to those pressure levels.
JamieP
Apr 7, 2012 05:11 AM
