Interior Light Not Working At All
I opened up the switch and cleaned it. That fixed the problem.
This isn't really an under the hood question so much as over the head.
I picked up an 02 last weekend, and the interior lights don't work... at all. I know that it's typical for the switch to corrode and need to be cleaned, but I thought the map light buttons would still work even if the switch didn't work well.
I checked the bulb, interior light fuse, and pulled the entire light assembly to make sure nothing fried, but I can't find anything wrong.
im 90% sure the switch will affect the map light...did you try clean the switch? i read you pulled the light assy, but not sure if you consider the switch a part of it...
IIRC, there was a small "ball" that creates contact, if someone popped open your light earlier and lost the ball/broke a connection you're SOL...?
IF you have a DMM try measure for power across the leads coming in?
My wife's Pilot had the same problem with her map light assembly. I replaced the holder module (around $30) and that fixed the problem.
Do you have a buddy you can swap holders with to test?
DangerZone9K
Mar 1, 2013 06:58 AM
