Intermittent Rattle @ Idle - AP1
Old Mar 1, 2016 | 10:32 AM
S2GARAGENYC's Avatar
Default Intermittent Rattle @ Idle - AP1
Alright so, this one really has me scratching my head here...
My car was purchased with 70,xxx miles, within the first week of ownership I installed OEM Honda TCT, Serp Belt, Tensioner, Idler Pulley, and did a valve adjustment.
Before and after I replaced these parts I have this exact same noise going on, can be heard in the first 5 seconds of this clip:
https://www.youtube.com/watch?v=hyNb...=youtu.be&hd=1
It comes and goes at idle only, either cold or hot. Considering all the parts are new, and out of adjustment valves would be a constant noise, I really can't figure this one out.
For what it's worth, the motor runs like a dream and takes everything I throw at it.
I'm no stranger to Honda engines, and have a good ear for things like rod knock, piston slap, etc. This falls in to none of those categories.
Old Mar 1, 2016 | 10:52 AM
windhund116's Avatar
Any chance you dropped a tool or part into the engine compartment?
Status of accessory belt and the pulleys?
Old Mar 1, 2016 | 11:19 AM
Accessory belt and pulleys are all brand new. I've put maybe 100 miles on this motor since doing a full service on it.
I'm very anal, so I covered every nook and crannie on this car since purchase with the exception of bushings.
Old Mar 1, 2016 | 11:43 AM
tozerman's Avatar
This seems to be an increasingly common noise, some people have spent a lot of money trying to eliminate it without success. My car has always done it cold/warm at idle only. As you say it is not tct,piston slap or rod knock.
My theory is the clutch release fork! there is a pivot pin on it which can work loose, I greased mine and the noise went away for a couple of days only, and I reckon that is the grease dispersing, a new fork would confirm/deny my theory.
https://www.youtube.com/watch?v=2GkWdHfFkjk
check this video out, and remember noise can travel around an engine.
Old Mar 1, 2016 | 11:53 AM
bgoetz's Avatar
Yeah tons of us have that noise and to date no one has determined the source with certainty. It isn't the clutch fork either, I just replaced my clutch. The good news is I have read no reports of this sound being anything more than an annoyance. I just drive it and don't worry about it, I figure I will fix it when and if it breaks.
Old Mar 1, 2016 | 02:08 PM
Glad to know I'm not the only experienced guy out here struggling with this one.
As we've all stated, it seems a lot like a "if it ain't broke, don't fix it" thing. The motor is stout in every other capacity, from compression to valves. If it doesn't get worse I doubt I'll continue stressing it.
Old Mar 1, 2016 | 03:27 PM
bgoetz's Avatar
I sorta narrowed the sound down to the timing cover or cylinder 1 area, but like most said sound travels, so who knows. My 06 actually did the same thing and it started right after winter storage.
Old Mar 1, 2016 | 05:34 PM
Mexs2k's Avatar
A lot of us have that noise and I'm pretty sure that most of us have it coming from the #1 piston and timing cover. At least mine does and it sounds exactly like the video he posted
Old Mar 1, 2016 | 09:59 PM
Yea, mine sounds just like that video as well. It definitely seems to come from the cylinder 1 area. But with a stethoscope right over cylinder 1, the rattle can be heard, however it doesn't replace the sound of the tappets.
I suppose we'll just have to live with it until someone pulls this rabbit out of the hat.
I can't hear it while I'm the cabin, so it isn't all bad, lol.
aidank
Feb 13, 2017 09:57 PM
Spartarus
Nov 8, 2016 03:12 AM
chief_67k
Oct 7, 2013 02:51 AM
ryan111987@hotmail.com
Apr 13, 2009 08:13 PM
2kturkey
Mar 18, 2002 03:40 AM
