Issue w/ 1st gear
Old Dec 11, 2002 | 12:21 PM
blaks2k's Avatar
Default Issue w/ 1st gear
All,
I have to admit I am neither an experienced manual transmission driver nor an experienced mechanic. That is why I came to you!
Sometimes I have a bit of trouble getting the car into first (from 2nd or less often Neutral). None of the other gears have this "stickyness". It happens about every fourth time I drive the car, so it is not really a big issue.
When it happens from neutral, I can usually go 2nd to 1st with no problem. Yes the clutch is fully depressed.....
The car is certified and a month old (2001).
Old Dec 11, 2002 | 12:44 PM
Gernby's Avatar
Former Sponsor
I have this same issue with my '02, especially when it's cold. I think it is just the way it is.
Old Dec 11, 2002 | 12:53 PM
blaks2k's Avatar
Thanks for the reply. I feel better now. Now that I think of it, it happens when it is very cold out.
Cheers...
Anyone else???????
Old Dec 11, 2002 | 12:57 PM
Benjamin's Avatar
Yes, 1st is this way on my '02, and especially when cold. I'm confident that this is as-design behavior.
Old Dec 11, 2002 | 01:00 PM
The Unabageler's Avatar
blip the throttle a little and it will slide into gear easier.
Old Dec 11, 2002 | 01:10 PM
Benjamin's Avatar
This is true - Rev matching is a must on downshifts, especially the large 2-1 shift.
Old Dec 11, 2002 | 01:21 PM
Woodson's Avatar
Old Dec 11, 2002 | 03:02 PM
I just replaced my clutch master and slave cyls...they were full of gunk! shifts are even easier now. try flushing your clutch fluid too.
Old Dec 12, 2002 | 07:02 AM
jeffbrig's Avatar
If you're completely stopped and it doesn't want to go into first gear, let the clutch out in neutral, this will get the layshaft spinning. Then when you push the clutch back in, you should be able to get it into gear.
If you're rolling and trying to get back into first, blip the throttle while the clutch is out in neutral. That gets the layshaft speed closer to the speed at which the gear is spinning, so it should go in easier.
Old Dec 12, 2002 | 07:08 AM
PWRMKR's Avatar
[QUOTE]Originally posted by jeffbrig
[B]If you're completely stopped and it doesn't want to go into first gear, let the clutch out in neutral, this will get the layshaft spinning.
