Issues with AP1 Not Starting
Old Nov 20, 2017 | 05:52 AM
honda4eva89's Avatar
Originally Posted by 2004s2k2004
Try pushing your clutch pedal really hard and see if that makes a difference, if that works I would suggest replacing the piece of plastic on the clutch. It could also be your immobiliser possibly. If your starter worked, chances are really low that the starter or the solenoid are your issue. I would also check your grounds, see if you can see any corrosion built up around grounding points. Hope this helps.
Looks like your immobilizer is working from the video.
1. Immobilizer does not prevent the engine from cranking
2. Starter solenoids can be very heat sensitive therefore symptoms won't always be there.
Old Nov 20, 2017 | 06:33 AM
windhund116's Avatar
Just wondering if any of those accessory electrical items you installed maybe drawing excessive current, when you try to start the engine. Esp, when car is cold.
Can you remove (via fuse or switch) these devices, before starting?
Old Nov 20, 2017 | 12:27 PM
hoobastnk90's Avatar
I am leaning towards an issue with the starter as well.
Old Nov 20, 2017 | 12:29 PM
Im sure there is a way, to prolly jump a circuit to power the starter, so you will know weather it cranks or not, suxs our starter is so hard to get too.
Old Nov 20, 2017 | 12:38 PM
GothamS2K's Avatar
Thanks for all of the recommendations!
I’ve decided to have the car towed to the Honda dealer to let them have a gander at it, which hopefully should be successful.
I’ll update the thread once I know the end result.
Old Nov 20, 2017 | 01:42 PM
The honda dealer...hopefully they take good care of you
Old Nov 29, 2017 | 02:38 PM
GothamS2K's Avatar
Just an update for anyone that may end up stumbling across this thread in the future...
I ended up skipping the Honda dealer and chose to take it to a really great local mechanic shop that was suggested by a friend, thus saving me a lot of money that I would have spent having gone direct to the dealer.
The issue has been resolved though, as it turns out that the port on the starter solenoid was not fully connected, thus causing the vehicle not to start.
Thanks again to all of you for the feedback and recommendations!
Carlos080596
Dec 30, 2018 01:23 AM
vicdeng
Oct 28, 2016 05:50 AM
R150
Oct 13, 2015 03:33 PM
Alen1293
May 17, 2015 06:14 PM
Fed
Jun 5, 2012 01:02 PM
