Iteration 2 of Custom Comptech Air Iintake
Old Jan 28, 2003 | 10:00 PM
Yellow Streak's Avatar
Default Iteration 2 of Custom Comptech Air Iintake
I swapped out my "hand made" coupler for a professionally made silicone coupler. One of the features that we put into the new coupler was a double hump to handle some of the movement when the motor is torquing to the passenger side. I also swapped out all of my hose clamps for beefier constant torque clamps. The original piece of silicone coming out of the blower was too short, so I put in a new longer section.
Here are some pics:
-YS
Old Jan 29, 2003 | 09:45 AM
shingles's Avatar
looks good, do you have any pictures on the filter setup in the fender?
BTW... I've been reading a lot on the effects of using a breather filter like you have set up. The general feeling I am getting is that that's a bad idea. The original setup is such that the intake manifold would create a vaccume to extrat the oil vapor as well as the pressure in the engine. By setting it up with the breather filter, it doesn't do this and cause cause blow by etc.
Anyone care to comment on this issue?
Thanks,
-S
Old Jan 29, 2003 | 09:54 AM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by shingles
[B]looks good, do you have any pictures on the filter setup in the fender?
Old Jan 29, 2003 | 09:56 AM
Old Jan 29, 2003 | 10:01 AM
Gernby's Avatar
Former Sponsor
Would it not be better to use another 90 degree bend through the wall, instead of the flex pipe? That flex is gonna cause a lot of turbulance. It also seems like it might colapse a bit when the SC really starts pumping.
Old Jan 29, 2003 | 10:09 AM
[QUOTE]Originally posted by gernby
[B]Would it not be better to use another 90 degree bend through the wall, instead of the flex pipe?
Old Jan 29, 2003 | 12:34 PM
KAMcDonald's Avatar
so, can i get your old stuff to use until i figure out what kind of aftercooler to use?
keith
Old Jan 29, 2003 | 02:46 PM
shingles's Avatar
[B]
I think the breather is necessary for FI, since you don't want to pressurize the valve cover.
Old Jan 29, 2003 | 03:45 PM
Gernby's Avatar
Former Sponsor
[B]
You could tap the intake before the compressor and place the tube there instead of the intake manifold.
Old Jan 29, 2003 | 03:49 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by hecash
[B]I'd be concerned about turbulence between the impeller and the throttle body but not so prior to compression.
