j's catch can install
Old Oct 19, 2009 | 09:20 PM
tekka01's Avatar
Default j's catch can install
so i recently installed a j's racing catch can, currently i have the lines routed like so:
pcv->catch can->intake manifold.
weird thing is, when i rev the car, i can hear a whoosing sound from the catch can. almost sounds like theres a leak in the catch can. however, i then tried plugging the intake manifold and just letting the catch can vent into the atmosphere like so:
and voila! the sound was gone. any idea why?! can't be a leak, otherwise i would still hear the sound using the second configuration. also, when i rev the car, i can kind of feel the metal on the catch can...expand for a lack of better words.
Old Oct 19, 2009 | 09:26 PM
chansta's Avatar
i would assume the "wooshing" sound might be due to the vacuum from intake manifold being worked on the catch can, or maybe because of the oil collected in the catch can making a "wooshing" sound from manifold vacuum?
metal on catch can expanding? well i assume this is due to the fact that the fumes coming out from the block is high in temperature, and as you know metal expands when heated.
jus sharin my thoughts.
o and is the catch can vented or non vented? maybe the area where u can put a filter on (for vented catch cans) might not have a complete seal. this could explain why you get wooshing sound only when catch can is connected to intake manifold.
Old Oct 20, 2009 | 10:19 AM
tekka01's Avatar
i was thinking the noise is a result of the vacuum from the intake manifold pulling air from the crankcase, but i dont understand why my previous catch can didnt make this noise
catch can is non vented
Old Oct 21, 2009 | 08:27 AM
terahertz's Avatar
maybe its the air wooshing thru what used to be just a rubber tube. turbulent flow inside the catch can?
tekka01
Oct 20, 2009 07:29 PM
run115
Jan 3, 2009 03:08 PM
dumped2k
Jun 14, 2008 12:02 AM
dagostino777
Jun 30, 2007 09:00 AM
speedracer03
Nov 17, 2004 07:28 AM
