J's Engine Tourque Damper Install Help
Old Nov 24, 2004 | 09:48 AM
learnerspermit's Avatar
Default J's Engine Tourque Damper Install Help
Im am installing one next week is there anyhting diffucult about installing it? It looks like you remove the Vtec solinoid is there a gasket behinde it? Or anything else If you have pics please post em!
Thanks
Eric
Old Nov 24, 2004 | 01:03 PM
honda9krpm's Avatar
there is no need to remove the vtec solenoid
you just bolt it into the engine, behind the vtec solenoid
Old Nov 24, 2004 | 03:54 PM
Stratocaster's Avatar
Thanks
Eric
No, you don't remove anything from the motor. There is a threaded hole just to the left. The supplied bolt goes into that location and holds bracket in place. The damper mounts to the bracket and to the STB mount.
Now you do have to cut the Fuse box mount from the car. That is why Iu had a custom mount made. I hate to cut anything.
Old Nov 24, 2004 | 04:11 PM
Flood5's Avatar
To those of you who have one, how do you like it? What difference did you notice?
Old Nov 24, 2004 | 08:54 PM
how hard is it to cut the fuse box mounting? what did you make to avoid cutting it?
Old Nov 24, 2004 | 10:32 PM
kane.s2k's Avatar
He told you what he made. Read his post and look at the picture.
Old Nov 24, 2004 | 11:01 PM
Nobody's Avatar
Last time I tried to get a J's Engine Damper I couldn't find one anywhere. Who sells 'em?
Old Nov 25, 2004 | 05:32 AM
fperra's Avatar
Bulletproof sells them, but you will have a long wait. I've been waiting 5 months and it still hasn't shown up.
Old Nov 25, 2004 | 07:13 AM
Slows2k's Avatar
You can read all about the fitment issues here:
https://www.s2ki.com/forums/index.php?showt...hl=Egine+damper
Old Nov 25, 2004 | 10:21 AM
Kodokan_4's Avatar
The OEM header heatshield won't fit with the J's aluminum heatshield. If you don't use a header heatshield, the temperature in your engine compartment will be much higher.
I made a header heatshield out of sheet aluminum and multiple layers of aluminum foil. It only took about 20 minutes to make and install, and it works (and looks) really good!
In this pic, you can see part of the custom header heatshield:
-Pete
PS- The engine damper is worth every penny, and the time spent installing it. It is absolutely functional and I highly recommend it!
