JDM Block with all the rest USDM
Old Nov 15, 2018 | 03:38 PM
BattleRaT's Avatar
Smile JDM Block with all the rest USDM
Initial Disclosure: Apologies in advance, I really tried to contact about 10 members who mentioned they did this "JDM block with USDM harness + ECU + vtec solenoid oil pressure sensor" but nobody replied (basically no longer in the forum). Please don't crucify me for asking this... AGAIN. It's really not properly documented in the forum, I really searched for days on this
Hi Experts,
Could somebody confirm the following?: "A JDM F20C block can be used without any problem with a USDM F20C1 harness + USDM F20C1 ECU + USDM F20C1 Oil Pressure sensor installed in the vtec solenoid".. According to my research the answer is YES but i'm not fully clear about this and I failed in getting confirmation from members who did JDM swap.
My big questions are:
- What about the AFR when using a JDM block that generate more compression on the pistons? Is the USDM ECU capable to compensate/adjust AFR?
- I read about a second knock sensor in JDM. Is that correct? Just leave it there unplugged and all should be fine, right?
- Any other feedback? Just want to put a fresh JDM block and use my USDM accesories, harness, ECU,etc. A clean swap just changing the block and keeping all the rest.
Thanks in advance for your guidance.
BattleRaT
Old Nov 16, 2018 | 06:43 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It will work, but you will likely get a CEL for recurring lean condition.
Old Dec 16, 2018 | 06:05 AM
rednikos's Avatar
some say that 2.2 can work with ap1 2000 ecu .I dont think that u will have problem.
Old Dec 16, 2018 | 06:10 AM
Billman250's Avatar
Top Answer: 1
Lean code is also common on AP1 with a 2.2L swap.
Old Dec 16, 2018 | 06:28 AM
Chuck S's Avatar
Curious if this is a merely lean code or an actual lean condition.
-- Chuck
petros ae86
Apr 30, 2015 04:00 AM
Russ_16v
Jan 4, 2013 01:00 PM
mugen888
Sep 16, 2011 02:30 AM
shiesty
Apr 21, 2010 04:22 PM
i</3speedbumps.
Jan 10, 2007 09:13 PM
