JDM f20c install?
Old Oct 13, 2007 | 09:48 PM
shiesty's Avatar
Default JDM f20c install?
I'm about to install a jdm f20c from japan into my car next week, i'm wondering if there are any differences between the jdm and usdm engines and what I should look out for/do during the swap? Thanks in advance.
Old Oct 14, 2007 | 05:00 AM
negcamber's Avatar
Don't forget to attach the ground at the back of the head otherwise it won't start.
Be careful when removing/installing the top starter bolt...it requires a long extention to get to it and you may accidently hit the knock sensor. Our knock sensor plug gets brittle quick and just a tap with the extension can shatter it.
Old Oct 14, 2007 | 06:53 AM
mikey k's Avatar
JDM engines different knock sensor and vtec solenoid arrangements, higher compression and a different ECU. Quite a few of UK owners have them. I doubt it will run on you USDM ECU from experience in the UK with engine swaps.
Old Oct 14, 2007 | 08:13 AM
Stratocaster's Avatar
I know of a few that have been installed here in the states. I don't know the details of the install, but they are running with the USDM OEM ECU. I know they swapped out the Vtec soleniod, and the JDM Engine harness (RHD v LHD Setup), but what else, I don't know.
Old Oct 15, 2007 | 08:34 AM
shiesty's Avatar
hmmm. I was informed that the usdm ecu will work fine. So sofar, use the usdm vtec solenoid and the usdm harness... is there anything else?
Old Apr 21, 2010 | 04:22 PM
crank's Avatar
dam anyone have more info on this ?
BattleRaT
Dec 16, 2018 06:28 AM
MazinUK
Sep 14, 2016 06:58 AM
Russ_16v
Jan 4, 2013 01:00 PM
mugen888
Sep 16, 2011 02:30 AM
i</3speedbumps.
Jan 10, 2007 09:13 PM
