jdm engine
Old Jul 31, 2011 | 06:45 PM
motoracer90's Avatar
Default jdm engine
Anyone ever run a jdm f20c with a usdm s2000 ecu? my engine is trash and thinking about getting a jdm engine. Just need to pass pa emissions.
Old Jul 31, 2011 | 09:40 PM
zbrewha863's Avatar
No you will most likely fail. JDM ECUs are not OBDII spec, and they don't run the air pump assembly the same way. I learned that when I bought that fiasco of a part Challenge made to eliminate the air pump.
Old Aug 2, 2011 | 03:32 AM
has anyone tried this? one person says you have to swap some parts from old motor and some person says it wont work.
Old Aug 2, 2011 | 06:25 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Id imagine it would work.
All your getting is the engine...use your intake manifold if needed.
Old Aug 2, 2011 | 08:24 AM
zbrewha863's Avatar
Oh my bad, I got that backwards, I thought you were using a JDM ECU on a USDM engine. The only difference I know of with the JDM engine is that it has a higher compression ratio, so run good gas!
Old Aug 2, 2011 | 01:30 PM
Billman250's Avatar
Top Answer: 1
Maybe someone from japan can post the min octane rating for a JDM engine. I thought it was 97 octane.
Old Aug 3, 2011 | 08:49 AM
anyone else have info?
Old Aug 3, 2011 | 08:53 AM
zbrewha863's Avatar
USDM engine - 11:1 compression ratio
JDM engine - 11.7:1 compression ratio
With the USDM ECU, I feel that running premium 93 octane is fine. The ECU will just retard the timing when it senses knock, so it should be safe enough, but you have to keep in mind that you are running a half-a**ed setup, so it's not going to be perfect.
Old Aug 3, 2011 | 08:57 AM
when you say not perfect, do you mean like throw check engine light on?
Old Aug 3, 2011 | 03:21 PM
zeroptzero's Avatar
How about running a thicker head gasket, I think getting the compression ratio to 11.5 could be a good operating point.
