Just did a compression test...
Old Jun 6, 2007 | 01:26 PM
2QYK4U's Avatar
Thumbs up Just did a compression test...
My wife has an '04 Civic with an '04 K20A2 in it. When we first did the engine swap, the motor "apparently" only had 1550 miles on it. Sure. Whatever. A compression test was done by the shop whom did the install and "apparently" checked out ok. Sure. Whatever. If the engine really had 1550 miles on it, it now has ~18K miles on it. I just did a compression test myself and here are the numbers:
#1 - 132
#2 - 134
#3 - 135
#4 - 133
With the exception of cylinder #3, the other cylinders are all below the factory minimum specs of 135. However, they are all really close to one another and are within the maximum factory range of 28 psi. With that in mind, it would seem to me that the engine probably has more than 18K miles on it and is getting "tired".
After doing the compression test, I installed new spark plugs. They are NGK 1ZFR6K11s, gapped to .040mm, and torqued to 18 ft-lbs. The car started and idle just fine.
Any feedback?
Old Jun 6, 2007 | 02:45 PM
s2kbtos's Avatar
HI:
It seems like the engine has more than 18k on it. for a high compression engine like the a2 the numbers should be higher. i did a compression test on my moms civic si with a k20a3 and the numbers were as follow:
1#145
2#145
3#140
4#128
Honda civic si 2002 with 86000 miles.
considering that the k20a3 has a 9:1 compression. your numbers should be higher.
on my Honda s2000 i got:
1#190
2#190
3#185
4#188
Old Jun 6, 2007 | 02:51 PM
vspc2nr's Avatar
what is the normal/minimal spec's for the S?? and isnt not more that 8% of the lowest cyl still good??
Old Jun 6, 2007 | 03:40 PM
Eluded's Avatar
was the compression check performed properly?
Old Jun 6, 2007 | 05:25 PM
2QYK4U's Avatar
In accordance with the factory service manual.
Old Jun 6, 2007 | 06:15 PM
Sobe_Death's Avatar
those compression numbers seem low to me. I had a dual cam ZC in my hatch and with the stock compression of 9.6:1 and fresh rings (~300 miles) I was getting between 190-200 psi across the board.
Then again, I have no clue how the cams affect the compression readings on the K-motors either.
Old Jun 6, 2007 | 07:40 PM
iam7head's Avatar
there's alot of variable: number of crank, battery condidtion, brand and condition of the gauge, user error.
you want a consistant number more than anything, i know my gauge reads on the low side.
did you get a wet test after the dry test?
Old Jun 6, 2007 | 08:01 PM
2QYK4U's Avatar
# of cranks: 4-5 (as per the factory manual)
battery condition: full charge
The gauge was brand new--just bought it from Kragen
What is a wet test? I did the test in accordance with the factory manual.
Old Jun 6, 2007 | 08:09 PM
2QYK4U's Avatar
The compression tester was manufactured by "Innova Equus" and the part number is #3614. I purchased the best compression tester that Kragen had to offer.
Old Jun 7, 2007 | 01:51 AM
SILAP1's Avatar
you had the throtle wide open right. holding the gas pedal to the floor while cranking . them numbers seem really low but atleast there even
