Just did a compression test...
Originally Posted by SILAP1,Jun 7 2007, 02:51 AM
you had the throtle wide open right. holding the gas pedal to the floor while cranking . them numbers seem really low but atleast there even
Do the test while the engine is warm.
Remove the fuel pump fuse.
Do it at WOT.
Different gauges give different readings. Also, warmer ambient temps give lower readings.
I also remove the plugs from the other 3 cylinders while doing the test, to minimize cranking effort.
Do it at WOT.
Originally Posted by s2kbtos,Jun 7 2007, 12:54 PM
just like i said. you will get the same numbers. are you sure you did a k20a2 swap and not a k20a3
Apparently the engine must be getting tired. We plan on selling it within the next 2 years or so, so it doesn't make any sense to go and rebuild it.
Originally Posted by SpaZilla,Jun 8 2007, 09:51 AM
was the car warmed up to operating temp?
