KAAZ LSD Fluid?
Old Aug 12, 2004 | 11:34 AM
s2kjones's Avatar
Default KAAZ LSD Fluid?
Ok, I've done the searches, and all I have now is a headache.
I have just had a KAAZ LSD installed on my S. Are there any other diff. fluids that I can use, other than the Fluid that KAAZ sells?(it's way to expensive, and difficult to get)
Old Aug 12, 2004 | 11:37 AM
kMfromLA's Avatar
http://www.kaazusa.com/contact.asp
Call them and they will ship it to you. I have the Kaaz 1.5 way and I only use their oil...
-kM
Old Aug 12, 2004 | 11:38 AM
Ludedude's Avatar
Administrator
You need to find out what's "magical" about the Kaaz fluid and see if anyone sells something similar. This is anecdotal only, so take it for that it's worth but I've hard of people using the Kaaz fluid for the break-in period and then switching to their regular fluid. Your mileage may vary and I take no responsibility for any damage that may follow as a result of you following that recipe.
If the Kaaz diff has special lubrication requirements due to its construction then you'd better find out if you can safely run any other fluid without damaging the unit.
Old Aug 12, 2004 | 11:54 AM
s2kjones's Avatar
-kM
Yep, gave them a call. GL-5 blah blah blah, ....friction modifiers blah blah blah...
Looks like it will be easier to stick with their fluid.
...thanks for the quick response.
$40 for 2 liters isn't that bad I guess
Old Aug 12, 2004 | 11:57 AM
Ludedude's Avatar
Administrator
Well, if it's GL-5 with friction modifiers then you probably have some options. Of course if they use boar mucous as a FM then you might be screwed
Old Aug 12, 2004 | 12:03 PM
s2kjones's Avatar
He said that I could use the friction modifier that Ford sells. For the S2000 use only 3oz. It comes in a 4oz bottle.
He also said not to use synthetic base fluids. This will cause your clutches in the lsd to be very loud.
Old Aug 12, 2004 | 12:16 PM
Ludedude's Avatar
Administrator
Well there you go.
I'm sure someone here has a recommendation then.
LE-607 while not specifically labeled GL-5, might be a suitable oil. It does not use synthetic base stocks. I'm sure someone more knowledgeable than I will chime in with empirical information.
RedCelica
Aug 27, 2016 02:48 PM
deegaw11
Dec 29, 2012 12:27 PM
spectacle
Jun 16, 2006 12:30 PM
TunedS2000
Aug 21, 2004 06:52 AM
