keyless door lock control unit
Actually no, my car is not RHD.
There are two seperate systems, Keyless Entry, and the Alarm.
The Alarm was an OEM option so not all S2000's have them.
If your fob has the word option written out instead of a trunk for the third button then you have the optional alarm system.
The Keyless Entry control unit is located behind the audio controls and start button, NOT behind the A/C controls.
The Alarm control unit is located under the drivers side seat.
The unit is just about behind the start button. It is rectangular in shape and has I believe a 16 or 18 pin connetion coming out the bottom of it. I just did the factory alarm install and I went through the same thing. You have to be on your back with your head almost under the steering wheel and look in the vicinity behind the starter button. It can be kinda tough to get the connector off but be patient and you will get it. Good luck.
Jim
Jim
