Unlocking both doors with one remote click?
Old Nov 1, 2006 | 07:31 PM
dewar's Avatar
Default Unlocking both doors with one remote click?
Has anybody figured out how to make both doors unlock with one push of the remote? I did see the article about wiring in an auxiliary switch to unlock the passenger door while sitting in the drivers seat (here https://www.s2ki.com/forums/index.php?showtopic=51052 ) but that isn't really what I'm going for. I scoured the archives and heard mention of a one push fix, but never found any directions. Any input is greatly appreciated!
Dewar
'02 Suzuka
Old Nov 1, 2006 | 09:10 PM
highwaystardoritos's Avatar
would like to hear about this also
Old Nov 2, 2006 | 06:34 AM
dewar's Avatar
Here is the response from Bob at Modifry
_______________________
As for the passenger door issue - that's an easy one. If you wire the passenger door lock in parallel with the drivers door lock they will operate at the same time for both locking and unlocking.
Under the driver's dash is the Keyless Entry Module (photo below). The driver's lock and passenger lock already share one common wire, a pink/black wire. But the second wires for each lock go to separate terminals so the module can control them individually. Find the pink/blue (passenger) and yellow/green (drivers) wires on the module. Cut the pink/blue about an inch away from the module and insulate the end going into the module. Strip the other end and splice it into the yellow/green (without cutting the yellow/green). Now both locks will operate as if they were the driver's door lock.
Note - the yellow/green may be yellow/white if you have a factory security system.
Bob
________________________________
Go buy something from this guy! If you have put in an aftermarket stereo his DCI is a must to retain the stereo controls on the dash! He also has lots of other neat stuff.
http://www.modifry.com
Old Nov 2, 2006 | 08:18 AM
cdelena's Avatar
He gave me the advice years ago when I asked and the mod is great.
downloader
Mar 21, 2009 09:48 PM
elude
Jun 30, 2005 04:15 PM
1Fast99Si
Jul 7, 2003 08:46 AM
