Knock sensor
Old Jan 23, 2009 | 12:19 PM
s2000 gib's Avatar
Default Knock sensor
Right, first a little background info:
Just undergone a rebuild as cylinder 4 was scratched. Had the block sleeved with Darton MID's, JE pistons and BC conrods. Have changed the clutch to an ACT with 6puck pressure plate and an 8lb Fidanza flywheel.
problem: Everything seems fine except the valves seem very noisy. Have only had them adjusted to loosest possible setting which explains that but I've got a knock sensor code P0325 Knock sensor malfunction bank 1. Even when the valves are adjusted properly I still get the cel. Could it be the cylinder clearances are still a bit tight (compression test is fine) and this is firing it off or could it be something to do with the sleeves?
I've kept compression the same and nothing else has been changed except from the essentials like big end bearings etc.
Kinda stumped, need help pls
Or is it something stupid like the sensor is just malfunctioning?
Old Jan 23, 2009 | 03:12 PM
negcamber's Avatar
The knock sensor was probably damaged...it is fragile. Replace it and clear the code.
Old Jan 23, 2009 | 04:45 PM
Soul Coughing's Avatar
either your knock sensor is damaged or the iron sleeves has changed the resonance of the block.
Old Jan 23, 2009 | 06:14 PM
Slows2k's Avatar
Sleeved blocks don't cause a P0325. Broken knock sensors do.
Old Jan 23, 2009 | 10:46 PM
s2000 gib's Avatar
Ok then guess I'll be changing the sensor on Monday and see how it goes.
Thanks for your replies people, much appreciated.
brokens2000
Mar 26, 2017 04:00 AM
Swiftoy
May 18, 2015 09:27 AM
cloud9bill
Mar 30, 2012 05:53 AM
superjiff
Mar 16, 2010 02:04 PM
JLuda
Jun 13, 2007 07:28 PM
