Knock sensor, where did you buy it?
Old Jun 20, 2010 | 04:13 PM
Carbon Blue's Avatar
Default Knock sensor, where did you buy it?
Hey fellas, I went to 9k first and 2nd(MY02 s2k)and the damn cel came on. Its not flashing and the car still drives perfectly fine. I went to go pull the code and it read "P0325 knock sensor circuit malfunction bank 1 or single sensor". After searching the code it seems that the Knock sensor by the starter seems to have been damaged during the clutch install (new clutch about a month ago).
Now here are the questions, what does bank 1 refer to? Is this the same knock sensor that is located by underneath the intake manifold driver side by the starter bolt?
Where did you buy yours from? The part number is 30530-PCX-003, I entered the part # in google and im not sure if I trust buying from the websites given, I went to check majestic honda, hardtop guy, and HANDA and none have the part number listed.
Old Jun 20, 2010 | 06:55 PM
CT S2K's Avatar
bank means cylinder head location . so on a 4 cylinder engine there's only one bank there for bank 1.
any V6,V8,V12,V16 have two cylinder heads, bank 1 and bank 2. The number just tells you if its the left or right cylinder head.
yes only one knock sensor
go to a honda dealership they will get you what you need. part numbers always change.
hope that helps
Old Jun 20, 2010 | 07:06 PM
thanks for the help and info!
4x4 freak
Dec 2, 2015 10:08 PM
cloud9bill
Mar 30, 2012 05:53 AM
superjiff
Mar 16, 2010 02:04 PM
s2000 gib
Jan 23, 2009 10:46 PM
bjonesz28
Sep 17, 2008 02:20 PM
