Knocking noise on idle
Old Sep 26, 2015 | 07:44 AM
KPS2K's Avatar
Default Knocking noise on idle
I know there are threads on this already but can find no definitive answer. I have an intermittent knocking noise on idle. It happens hot or cold and is there sometimes and others is quite. I done the valve adjustment and it seems to have helped. There is no obvious signs of wear under the cover, the TCT was refurbed not long ago and i have run the car with no belt to rule out pulleys. Anyone got any ideas ? doesn't seem like rod bearing play as it doesn't increase with rpm.
Old Sep 26, 2015 | 10:20 PM
Soviet's Avatar
Post a video. Help us help you. Hearing the noise will help us alot.
Old Sep 28, 2015 | 09:37 AM
KPS2K's Avatar
https://www.youtube.com/watch?v=_aEc2DCF2GM here's a link, any help appreciated. The noise used to be alot worse, since i've done oil change, valves it seems to have helped.
Old Sep 28, 2015 | 09:43 AM
s2000Junky's Avatar
Is that the sound that does an intermittent double tap kind of thing? I couldn’t quite hear from vid but that’s what it sounded like. I had a similar sound and it would also click when i revved the motor up. Turned out to the be the main belt tentioner itself. But you said you ran with no belt and still heard the sound, so that would rule that one out. The most obvious then would be either a lose valve or the tct still acting up. Not sure what else it would be.
Old Sep 28, 2015 | 11:25 AM
KPS2K's Avatar
Cheers @s2000Junky , Ive recently replaced the belt tensioner as the bolt sheered on changing the belt, was brittle as hell. Like i said its been run with no belt, which means if it was a pulley it would be crank, although it seems a tad far fetched. But yes it was the double tap noise you hear. I have a video of what it was like before, ill upload it and see what you think.
Old Sep 28, 2015 | 11:27 AM
Soviet's Avatar
I'm still a bit confused as well. A second video would help. I had an intermittent sound like that and it turned out to be my AC compressor but since there is sound with no belt
Old Sep 28, 2015 | 11:33 AM
KPS2K's Avatar
https://www.youtube.com/watch?v=buMasCHh8Vg this was the noise prior to the oil change and valve clearances being done, sorry for the spelling on the title, was in a rush. It is nowhere near as bad but is still present.
Old Sep 28, 2015 | 11:35 AM
KPS2K's Avatar
yea @Soviet i've been stumped by it for a while, i just don't want to harm the motor :/
Old Sep 28, 2015 | 11:47 AM
engifineer's Avatar
Does it stop when you press in the clutch?
Old Sep 28, 2015 | 01:45 PM
KPS2K's Avatar
I originally thought about trying that but forgot last time i was out. I'll have a go when im out next. Would the TCT make noise even when cold, as it was a horrific rattle when hot. Any other thoughts on what to look at ?
thanks for your help guys
tx2K
Dec 26, 2012 04:19 PM
JohnEan90
Mar 6, 2010 11:53 PM
Dilbert
Jul 13, 2009 02:29 PM
IlleztImportz
Jan 16, 2009 01:39 PM
bizlipkick
Jul 12, 2006 07:38 AM
