knocking from the rear end.
Old Dec 9, 2008 | 08:53 AM
skaterboyroland's Avatar
Default knocking from the rear end.
i got off work at 830 in the morning today, and i live in washington. its really cold lately. neways.. i get in my car, let it warm up till its idling under 1k, put it in reverse, and start to pull out. soon as the car starts moving backwards, i hear a knocking. i stop and so does the knocking. i put it in first, pull forward.. and no noise. i put it back in reverse, and as soon as i start moving, a loud knocking. once again, i put it in 1st, drive forward, and no noise. so i finally put it back in reverse, start moving backwards.. and the knock continues as i continue in reverse. i stop.. put it in 1st, and drive away... no knocking. i drive home, about 10 miles, all the while.. no knocking or noise. i stop on my driveway.. put it in reverse, and i drive backwards.. and this time.. no noise. i drive around in reverse, and the noise doesnt come back once.
any ideas?
its a 2000 s2k with 63000 miles. i dont know when that last diff fluid change was.. but i just got the fluid to do it. also.. the weather just started getting really cold.
any suggestions at all would be really awesome.
Old Dec 9, 2008 | 08:58 AM
JakeJewler's Avatar
This has happened to a buddy of mine. It only occured a couple of times on his 2003 s2k while backing out of the driveway. I'm sure he changes the fluids regularly. His S has quite a bit more miles than you as well.
Old Dec 9, 2008 | 09:00 AM
was anything wrong with the diff or anything.. or is his car still running fine?
Old Dec 9, 2008 | 09:04 AM
Onehots2k's Avatar
This happened to me a few times too. It happened before I changed the fluid. I changed my rear diff fluid since then though. My car is a 2004 with 90,000 miles. I havent heard it since.
Old Dec 9, 2008 | 09:49 AM
Nickamsweet's Avatar
Wait till it's cold again and do the same test again... if it happens then it's most likely the diff oil.
Then just check the levels or even perform a diff oil change... (never hurts)
aw11
Sep 29, 2018 06:48 PM
TrumpetTitan
Sep 12, 2011 01:37 PM
DERF
Aug 16, 2006 03:50 PM
MikeC
Sep 27, 2004 05:52 PM
n155a21
Mar 17, 2004 06:11 PM
